Person - Characteristics
The characteristics page contains information that describes miscellaneous information about the person. Use Menu > Customer Information > Person > Search and navigate to the Characteristics page.
Description of Page
You can only choose characteristic types defined as permissible on the person record. Refer to Setting Up Characteristic Types & Their Values for more information.
The following fields display:
Effective Date Define the date on which the characteristic becomes effective. The effective date defaults from the Installation Record.
Characteristic Type Indicate the type of characteristic.
Characteristic Value Indicate the value of the characteristic.
