Premise - Alternate Address
Warning:
This tab only appears if you have enabled alternate addresses on the installation record. Refer to the description of the Alternate Representation field under Installation - Main for more information.
This page is used when you have an alternate way to define a premise's address. This is typically used in countries that use multiple character sets (e.g., the Main address is entered in Chinese, the Alternate Address is entered in English). When a premise has an alternate address, both the main and alternate addresses can be used to search for a premise.
Open Menu > Customer Information > Premise > Search and navigate to the Alternate Address page to maintain this information.
Description of Page
The remaining fields on the page are used to define the premise's alternate address.
The address's constituent fields vary based on the Country. Country is always protected on this page because a premise's alternate address must be located in the same country as its main address. Please refer to the Country page for more information about address constituents.
Default note. An alternate address's state, city and county default from your postal default information. Refer to Setting Up Premise & Service Point Postal Defaults for more information.
The Swap Main / Alt Address button becomes enabled when you've entered an Alternate Address. When clicked, the contents of the address on the Main tab are swapped with the Alternate Address.
