Service Point - Multiple Items
The multi-item page is used to define the non-badged items that exist at the service point. Refer to Service Points With Multiple Items for more information about when to set up this information for a service point.
Use Menu > Customer Information > Service Point > Search and navigate to the Multi-Item tab to open this page.
Description of Page
Billing accumulates all unbadged items linked to a service point and levies a charge for each type of item based on information in the service agreement's rate.
The collection of items at a service point is effective dated and therefore when you modify this information, you must differentiate between:
Correcting how the collection of items looked historically by changing existing data.
Adding another collection of items to reflect how the items look after field work has taken place.
Removing Multi-items from a Service Point. If you want to remove all multi-items from a service point, add a multi-item collection that doesn't include any items. The effective date should be the date the multi-items were removed from the service point (i.e. no longer applicable to the rate).
Define the Effective Date of the collection of items.
The following fields display:
Item Type Indicate the type of item, its description is displayed adjacent.
Item Count Indicate how many of the given type of item exist at the service point.
