MUP1 - Populate Meter Configuration
This process populates the meter configuration ID on all MR upload staging records that don't have a meter configuration ID.
You don't have to know the meter configuration in order to interface a read into the system. Rather, you can specify a SP Geo Type and Value and/or a Meter Id Type and Value and/or the meter's badge number on the
Upload Register Read record. MUP1 will search the system for each (in that order) until a unique match is found.
Any errors detected during this process are written to the
MR Upload Exception table. You can fix errors using MR Upload Staging page (don't forget to change the record's status back to Pending ).
Parent topic
