Setting Up Trends
CAUTION:
You must thoroughly understand the information discussed in
Estimating Using Trends before you can understand trends.
Trend information is used to estimate consumption. A separate trend is maintained for every combination of trend area, trend class, unit of measure and time of use code. Each trend maintains a separate record for each day on which consumption was measured. This section deals with the issues associated with the maintenance of trend information.
Parent topic
