Step Type | What Happens |
NS - Connect Service Point | Changes the connection status of the field activity's service point to connected and removes the disconnect location (if any). It then updates the related step to reference the service point. |
DS - Disconnect Service Point | Changes the connection status of the field activity's service point to disconnected and populates the disconnect location with the supplied value. It then updates the related step to reference the service point. |
IM - Install Meter | Creates a new SP / Meter record and links to it the meter read inferred from the badge number and read date/ time. Note: the meter read upload process creates this meter read. It then updates the related step to reference the SP / Meter record. |
NM - Turn On Meter | Creates a new turn on event under an exist SP / Meter record. It links the meter read inferred from the badge number and read date/ time to the turn on event. Note: the meter read upload process creates this meter read. It then updates the related step to reference the SP / Meter record. |
FM - Turn Off Meter | Creates a new turn off event under an exist SP / Meter record. It links the meter read inferred from the badge number and read date/ time to the turn off event. Note: the meter read upload process creates this meter read. It then updates the related step to reference the SP / Meter record. |
MR - Read Meter | It's important to note that the meter read upload process creates this meter read. When this type of step is uploaded, the system simply updates the related step to reference the previously created meter read. |
RM - Remove Meter | Updates an existing SP / Meter record to indicate the meter has been removed. It does this by linking the meter read inferred from the badge number and read date/ time. Note: the meter read upload process creates this meter read. It then updates the related step to reference the SP / Meter record. |
II - Install Item | Creates a new SP / Item record using the supplied badge number and event date and time. It then updates the related step to reference the SP / Item record. |
NI - Turn On Item | Creates a new turn on event under an exist SP / Item record. It then updates the related step to reference the SP / Item record. |
FI - Turn Off Item | Creates a new turn off event under an exist SP / Item record. It then updates the related step to reference the SP / Item record. |
RI - Remove Item | Updates an existing SP / Item record to indicate the item has been removed. It then updates the related step to reference the SP / Item record. |
