How To Reprint A Specific Field Order
If you need to reprint a specific field order, navigate to
Field Order - Main Information and change the order's status to Dispatched.
If your implementation has
enabled the online creation of field order images, you can also click the
Display Field Order button on this page and then print the resultant online image on your local printer.
Parent topic
