Field Name | Format | Source/Value/Description |
DISP_GRP_CD | A8 | CI_FO / Dispatch Group code |
REP_CD | A8 | CI_FO / Representative code |
STATE | A6 | CI_PREM / State of the Premise address |
CITY | A30 | CI_PREM / City of the Premise address |
POSTAL | A12 | CI_PREM / Postal Code of the Premise address |
ADDRESS1 | A64 | CI_PREM / first line of the Premise street address |
PREM_ID | A10 | CI_FO / System-assigned identifier for the Premise |
SCHED_DT | D10 | CI_FO / Scheduled date of the Field Order |
SCHED_TM | T15 | CI_FO / Scheduled time of the Field Order |
FO_ID | A10 | CI_FO_STG_DWN / System-assigned identifier of the Field Order |
FO Group [Artificial] | N2 | This field forces the Service Point record group(s) into a position subordinate to the Field Order. Values: 10 - Field Order 30 - SP 90 - End Field Order |
SP Sequence [Artificial] | N2 | If there is more than one Service Point on a particular FO, this field forces them into an arbitrary sequence. Each SP is then followed by its device and Field Activity record group(s). |
SP Group [Artificial] | N2 | This field forces the device (meter, item or multi-item) and Field Activity record groups into a position subordinate to the Service Point. Values: 10 - SP 20 - Item 30 - Meter 35 - End Meter 40 - Multi-Item 45 - End Multi-Item 50 - FA 60 - End SP |
Sequence Number READ_SEQ [Artificial] [Artificial] | N3 | This field serves the same purpose in three distinct areas: Register Sequence (within a Meter record) (CI_REG) Item Sequence (within a Multi-Item record) FA Sequence (within a Service Point) In each instance, it forces the subordinate records into the correct order within, respectively, the Meter, Multi-item and Service Point record sub-groups. |
STEP_SEQ_NBR | N3 | CI_FA_STEP In addition to the "natural" values from the CIS database, there are two artificial values that serve to force a particular record into its proper place within the FA sub-group: 000 - Credit & Collections record 999 - End FA record |
FA Step Group [Artificial] | N2 | Each FA Step will have one or more FA Step (action) records. This field is to force these records into an arbitrary sequence within the FA sub-group. Values: 10 - Enter Meter Badge Number 20 - Enter Item Badge Number 30 - Enter Customer Contact 40 - Enter Reconfigure Register 50 - Enter Disconnect Location 60 - Enter Register Reading 70 - Enter Multi-item 80 - Enter Trouble Order Statistics 90 - Enter Changes 98 - Generic (placeholder) 99 - End FA Step |
