Billable Charge - Line Characteristics
Characteristics may be associated with billable charge lines. Typically, this is done to categorize billable charge lines for reporting purposes.
Open > > > and navigate to the Line Characteristics page to maintain characteristics that are associated with billable charge.
Description of Page
The Billable Charge Line scroll defines the billable charge line to which you wish to assign characteristic values. The following fields display:
Characteristic Type The type of characteristic.
Characteristics Value The value of the characteristic.
You can only choose characteristic types defined as permissible on a billable charge line. Refer to
Setting Up Characteristic Types & Their Values for more information.
Parent topic
