Billable Charge Upload - Main
Open this page using > > >
Description of Page
Fastpath:
Refer to
Billable Charge Upload Staging for more information about these fields.
Correcting Errors. If a Billable Charge Upload record's status is Error , you should correct the problem and then change its status back to Pending. The next time the billable charge upload process runs, it will revalidate the record and, if valid, it will create a billable charge record.
Parent topic
