Field Name | Format | Source/Value/Description |
Bill Print Intercept | A8 | This is the user ID, if any, who reviews the bill (as specified on the account record) |
Bill ID | A12 | |
Sequence Number | N2 | The sequence number of the account / person information associated with this bill routing information. |
Copy Number | N2 | The number of copies desired by the account / person associated with this bill routing information. |
Bill record group | A2 | 10 Bill 20 Payment 30 Current charge 40 Message 50 Non-Premise 55 Non-Premise end 60 Premise 70 Bill end |
Filler | A2 | |
Premise State | A6 | Only applicable for Premise based records. |
Premise City | A90 | Only applicable for Premise based records. |
Premise Address 1 | A64 | Only applicable for Premise based records. |
Premise Id | A10 | Only applicable for Premise based records. |
Premise record group | A2 | 10 Premise record 20 SA level record 30 Premise end record |
SA Print Priority | A2 | |
SA Id | A10 | |
SA Group | A2 | For Premise based records: 10 SA 20 Histogram 30 Current charge 40 Adjustment 50 SA end record For Non-Premise based records: 10 SA 20 Current Charge 30 Adjustment 40 SA end record |
Bill Segment End Date | A10 | If the record is related to an adjustment, this is the adjustment creation date. If the record is for histogram detail, this contains the histogram detail number. |
Bill Segment Id | A12 | If the record is related to an adjustment, this is the adjustment ID. |
Bill Segment Group | A2 | 10 Bill segment 20 Bill segment calculation group 30 Bill segment read detail 40 Bill segment SQ detail 50 Bill segment item detail 55 Bill segment message 60 Bill segment end |
Bill Calc Header Sequence | N2 | For records related to read detail, SQ detail, item detail or bill message detail, this field contains the related sequence number for that record. |
Bill Calc Header Group | A2 | 10 Bill calculation header 20 Bill calculation line 30 Bill calculation end |
Line Seq | N3 | Defines order of rows for similar record types |
Filler | 47 | Only applicable for non-premise based records. (This makes up for the premise address related fields that are not applicable above). |
