How To Adjust A Service Agreement On A Budget
If you need to adjust the debt on a service agreement that's on a budget plan, you have to ask yourself why you're adjusting the balance:
• If you're adjusting the balance to correct the payoff balance (for whatever reason), choose an adjustment type that just affects this balance.
• If you're adjusting the balance to correct the current balance (for whatever reason), choose an adjustment type that just affects this balance.
• If you need to adjust both balances equally, choose an adjustment type that affects both.
Parent topic
