How To Change Collection Events
When a collection process is first created, it has one or more collection events. The events are the activities that will be performed to persuade the customer to pay the outstanding debt.
The number and type of events that are created when a collection process is initiated are defined on the collection process's collection process template. The following points describe how to add / change / delete events on a collection process if the defaulted events are not satisfactory.
• Use Control Central to choose the account with the collection process whose events need to be changed.
After the account is populated on Control Central, choose the > option on the account context menu to transfer to the collection process transaction in update mode.
To add a new event, transfer to the Events tab and press the + button in the Collection Events scroll to add a new event. At this point, the event has not been added to the database; rather, it just exists in memory. Before you add the event to the database, you must specify the following information:
• Choose an Event Sequence so that the new event will be positioned properly in respect of the other events.
• Choose a Collection Event Status of Pending.
• Choose the desired Collection Event Type.
• Use Trigger Date to define the date on which the event should be activated (i.e., completed).
To delete an existing event, transfer to the Events tab and use the scroll arrows to toggle to the desired collection event. When the desired collection event appears, press the - button to remove the event. At this point, the event has not been removed from the database; rather, it's been removed in memory.
To change an existing event, transfer to the Events tab and use the scroll arrows to toggle to the desired collection event. When the desired collection event appears, make the desired changes.
After all desired changes have been made, save the collection process.
Parent topic
