Write-Off Event Activator
The Write-Off Event Activator (WET) runs periodically (at least daily). It looks for write-off events with a trigger date on or before the current date. For each such event, the system executes its activity and then completes it.
This process has an optional input parameter for CIS Division. It can be used if you implementation requires processing of data by CIS Division. You will need to create a copy of this process’s batch control for each CIS Division.
In the above
diagram, the write-off event activator activates a pending event on 15-Jan-2000. Notice that the event is moved to the Complete state.
Parent topic
