If you need to find the match event on which a financial transaction (FT) was matched, display the FT in question on
Financial Transaction - Main and then use the "go to" button adjacent to the
Match Event to drill to the match event.
The easiest way to display a financial transaction is to find its corresponding
bill,
payment or
adjustment and then drill down on the desired transaction.
