Billing Time Examples
Let's look at some examples for:
• Current Day Option
• Previous Day Option
• First Bill Segment
Current Day Option
• Assume that the
consumption period is from the 1st of October through the 29th of October.
• Assume the cutoff time on the service agreement is 2 a.m. and the start day option is Current Day.
To determine the starting interval, the system finds the first interval after the cutoff time on the billing start date. The system uses all the intervals up to and including the cutoff time for the DAY AFTER the billing end date.
Previous Day Option
• Assume that the
• Assume the cutoff time on the service agreement is 10 p.m. and the start day option is Previous Day.
To determine the starting interval, the system finds the first interval after the cutoff time on the DAY BEFORE the billing start date. The system uses all the intervals up to and including the cutoff time for the billing end date.
Fastpath:
Refer to
Bill Period and Seasonal Time Shifts for more information about the effect of time shifting on determining the bill period.
First Bill Segment
When billing calculates the consumption period for the very first bill segment for your service agreement, it uses a flag on your SA type to correctly calculate the
initial consumption period . For your interval billing service agreements, you typically configure your SA types to indicate that the start of the consumption period for the first bill should include the SA start date unless this is a 'back-to-back' situation (i.e., a previous customer was already billed for that day as its end date).
Let's look at an example. Imagine your SA type is configured to Add 1 Day for Back-to-back and this is not a back-to-back situation. Also imagine that your service agreement has the following defined:
• Start Date: April 1, 2003
• Start Day Option: Current
• Cutoff Time: 2am
The start period for the consumption period would be set to April 1, 2003; 2am.
Imagine the same SA exists, but this is a back-to-back situation. In other words, the previous customer ended service on April 1, 2003. Assuming the previous customer has the same start day option and cutoff time, they are billed through April 2, 2003; 2am. Refer to
Current Day Option for more information. In this case, billing calculates the start period for the consumption period as April 2, 2003; 2am.
Parent topic
