Hedge Cover - Profile Types
Create Profile Types
Set up a Profile Type HEDGE30 for the Hedge Cover, with the following attributes:
• Subtype is Common
• Minutes Per Interval is 30 minutes
• Specify an appropriate UOM/SQI
Set up a Profile Type MEAS30 for the Measured Usage, with the following attributes:
• Subtype is SA Owned
Set up a Profile Type OVRUND30 for the Difference between Measured and Hedge, with the following attributes:
• Profile Algorithm Type is Creation with an appropriate creation algorithm. The algorithm type IPFCSACS (supplied with the product) adds or subtracts two curves. The new algorithm should set up the two source Relationship Type parameters as HEDGE and MEASUSAGE and should indicate " - " for the Add/Subtract parameter.
Update Profile Relationship Types
Now that you have created profile types, go back to each profile relationship type and link the appropriate profile type as valid.
Parent topic
