Hedge Cover - Service Agreements
When starting service for a customer, choose the appropriate SA Type and start option. Upon creation of the SA, the following occurs:
• The appropriate rate is linked.
• The common profile created above is linked to the SA.
• Two new SA owned profiles are created for the SA using the profile types defined in the start option for measured usage and amount over /under the hedge.
Parent topic
