How To Correct a Register Data Set in Error
The validation algorithms are validating data in existing data sets. The following describes the steps involved with fixing an error found by the validation algorithm (IRGVDS-SMP) supplied with the system.
• Review the To Do entries generated as a result of interval register data exceptions.
• The information displayed with the To Do entry provides details of the error. You may also drill down to the Data Set page to view the error.
• Fix the error and change the status of the data set to Pending. The next time the validation algorithm runs, it revalidates this data.
Parent topic
