Installation of Interval and Index Channels
Installing a configuration for an index or interval channel to a service point is the same procedure as installing a configuration of standard registers.
• You must define the meter configuration that is being installed.
• The installation is effective-dated. There must be a meter read on the install date.
Note that for interval registers, register reads are not allowed. However, you may create meter reads without register reads in order to install a meter configuration with interval registers on a service point.
Fastpath:
Refer to
SP/Meter Installation for more information about installing meters at service points.
Parent topic
