Interval Data Set
You must create a data set for each batch of records being uploaded in the system for the same profile. The name of this table is CI_​INTV_​DATA_​SET. The following table describes each column on this table.
Column Name
Length
Req'd
Data Type
Comments
INTV_​DATA_​SET_​ID
12
Y
A/N
This is a unique key. This key is referenced on the interval data record.
It's suggested that this key is built as follows:
The first five digits are the first five digits of the INTV_​PF_​ID
The last seven digits are randomly generated.
This facilitates set based processing of the data. If your process that inserts records on this table is capable of calling a routine, call ProgramCIPZKEYG passing the first five digits and it supplies a seven digit random number.
INTV_​PF_​ID
12
N
A/N
This is a foreign key reference to the interval profile to which this set is linked. It is required if an external ID is not specified.
INTV_​DS_​EXT_​ID
60
N
A/N
This is the external identifier of the profile to which this data belongs. It is required if profile ID is not specified.
SET_​DTTM
26
Y
DateTime
This is the date/time that the data set was received. This must be populated with the current date/time. This is considered a server date and follows the seasonal time shifting as defined on the base time zone. Refer to Seasonal Time Shifts for more information.
Refer to Algorithms Find the Most Up-To-Date Data for information about why this date/time is important.
SET_​STATUS_​FLG
2
Y
A/N
Set this value based on whether it will be validated in the system.
Set to P for Pending if the profile ID is blank or if the profile's profile type indicates a validation algorithm.
Set to C for Complete if the data should not go through any further validation.
Refer to Life Cycle of Interval Profile Data for more information
