Process X - Populate Classic TOU Map Data
Process X refers to the mechanism used by your organization to populate the classic TOU Map Data tables. Process X has the following responsibilities:
• It determines the appropriate classic TOU map to which this data belongs. (Recall that the classic TOU map can hold an external ID.)
• It creates a new TOU data set with the current date and time.
• If the classic TOU map data is from a different time zone or is not in standard time for the base time zone, the time of each interval is converted to standard time in the base time zone. Refer to
Time Zone and Time Changes for more information.
• All quantities being uploaded for the same classic TOU map should be inserted into the TOU map data table and should reference the same TOU map data set.
• Inserts a record in the TOU data set key table.
The topics in this section describe the tables to populate.
Parent topic
