TOU Data Set Key
When a system-generated key value is assigned to a record, you need to also store the key value in a key table that corresponds to the record's database table. The name of this table is CI_TOU_DATA_SET_K. The following table describes each column on this table.
Column Name | Length | Req'd | Data Type | Comments |
TOU_DATA_SET_ID | 12 | Y | A/N | This should be your newly created TOU Data Set ID from above. |
ENV_ID | 6 | Y | N | |
Parent topic
