Classic TOU Map Common To a Subset of Service Agreements
If not all service agreements linked to your rate use the same classic TOU map for a TOU pricing rate component, it may still be the case that a subset of those service agreements use the same classic TOU map. In this case, the appropriate classic TOU map for each service agreement must be linked to the appropriate common classic TOU map.
To set up these types of service agreements correctly, the appropriate start option should indicate the common classic TOU map to link to the SA. Refer to
Designing Your IB Start Options for more information.
Parent topic
