Tunnel Option - Service Agreements
When starting service for a customer, choose the appropriate SA type and start option. Upon creation of the SA, the following occurs:
• The appropriate rate is linked.
• The common profile created above is linked to the SA.
• Three new SA owned profiles are created for the SA using the profile types defined in the start option for measured usage, inside tunnel and outside tunnel.
Parent topic
