Determine The Place Of Start/Stop
Before you can design your campaigns and packages, you must determine if your organization will use
start / stop to initiate new service agreements or whether new service can be initiated using the
order transaction. Refer to
Order versus Start / Stop for information to help you make this decision.
If you decide to use
start / stop to initiate service, we'd recommend creating the following types of campaigns:
• If your organization performs marketing surveys, you may also want to create a campaign similar to that described under
Marketing Surveys.
If you decide to use the
order transaction to initiate new service, follow the steps outlined in the following sections. Note that we use the example described under
Packages Limited By Answers And Field Values when describing the design process.
Parent topic
