Group No. | Group Description | If Group is TRUE | If Group is FALSE |
1 | Residential, Calif, Non Senior, Single Family, Gas Heat | Eligible | Ineligible |
Group 1: Residential, Calif, Non Senior, Single Family, Gas Heat | |||||
Seq | Field to Compare | Comparison Method | If TRUE | If FALSE | If Insufficient Data |
10 | Algorithm: retrieve order's customer class | = R | Check next condition | Group is false | Group is false |
20 | Algorithm: retrieve order's division | = CA | Check next condition | Group is false | Group is false |
30 | Misc Field On Order: Date of Birth | Algorithm: True if senior | Group is false | Check next condition | Group is false |
40 | Misc Field On Order: Type of Residence | = S (single family home) | Check next condition | Group is false | Group is false |
50 | Misc Field On Order: Type of Heat | = G (gas) | Group is true | Group is false | Group is false |
