Sequence | Description | Criteria Field Algorithm | Operator | Comparison Value | If True | If False | If Insufficient Data | Criteria Execution Point |
10 | Residential customers | Retrieve Customer Class (Define an algorithm instance for base algorithm type C1-ICGETACEL, Retrieve account attribute) | = | R | Check next condition | Not Eligible | Not Eligible | Both (lead generation and enrollment) |
20 | Average daily usage > 10 kWh | Retrieve average daily kWh usage (Define an algorithm for base algorithm type C1-ICGETAVSQ, Retrieve average service quantity) | > | 10 | Check next condition | Not Eligible | Not Eligible | Both (lead generation and enrollment) |
30 | Not on a smart rate program | Retrieve all contract options (Use base algorithm C1-ICGETCOPT) | = | 295076574659 (Contract option for smart day events) | Not Eligible | Check next condition | Not Eligible | Both (lead generation and enrollment) |
40 | Account is current | Check if Account Is Current (Use base algorithm C1-ICCHKACCU) | = | true | Check next condition | Not Eligible | Not Eligible | Both (lead generation and enrollment) |
50 | Active service on eligible rate | Retrieve all active rates (Use base algorithm C1-GETACTVRT) | IN | ERES1, ERES2 | Eligible | Not Eligible | Not Eligible | Both (lead generation and enrollment) |
10 | Premises with E-RES (electric residential) service points | Retrieve Premise SP Types (Base algorithm C1-ICPRMSPTY) | = | E-RES | Eligible | Not Eligible | Not Eligible |
