Order - Cancel Dialog
The Order - Cancel dialog opens if you press the Cancel button on the order transaction. You use it to define why the order is being canceled.
Description of Page
Use Cancel Reason to define why the order is being canceled.
Use
Log Notes to describe why the order is being canceled. This information appears in the
log entry that is created by the system when you cancel an order.
Parent topic
