Moving Rows Up and Down
The SQ Rule and Register Rule grids contain sequence numbers that indicate the order in which the rules should be executed. You may modify the execution order using the up and down arrows.
You may also need to renumber the sequences so that your rules are executed in the proper order. The fields Start from sequence number and Increment By are used to define the sequence number to assign to the first rule and the subsequent values to assign to subsequent rules.
Once the record is saved, both register rules are marked as Original.
Parent topic
