Pressure Factor - Bill Factors
Set up a bill factor called PF ADJ . On the bill factor, indicate that it uses the TAKEPT characteristic. Create a bill factor value for each take point to define its respective pressure factor.
Parent topic
Gas Pressure Factor Adjustments
This site works best with JavaScript enabled
