Rate Version - Main
Use > > > to maintain a rate version.
Description of Page
Rate Version contains basic information about the rate version. This information only appears after the rate version has been added to the database.
Rate Schedule defines the rate linked to the rate version. Effective Date defines the date when the rate version's rate components become effective. These fields are the unique identifier of the rate version. Both fields become protected after the rate version is added to the database.
Multiple rate versions may be prorated. When the system creates a bill segment for a service agreement, it checks if multiple rate versions are in effect during the bill period. If so, it uses the
rate schedule's Allow RVs Proration switch and
RV Selection Date flag to determine if it should prorate the various rate versions or if it should pick one of the rate versions effective during the bill period.
The
Rate Version Status indicates the current state of the rate version. Refer to
Lifecycle of a Rate Version for more information.
Warning:
Billing ignores rate versions that are not in the Finished status. This means that if you create a new rate version and forget to finish it, billing will use the prior rate version when it calculates the customers' bills.
Specify the description of the rate version in Description on Bill. This description is saved on bill calculation details created using this rate version. The following table illustrates the substitution variable(s) that may be used to substitute variables into the description during billing:
Substitution Character | What It Does |
%D | Replaces the substitution character with message 10101 from message category 4. This message is maintained in the standard message table. We recommend this message be set to "(prorated for %1 of %2 days)" where %1 will be substituted with the number of days of prorated consumption charged on the bill line and %2 will be the "normal" days associated with the rate's prices. This message will only be substituted when the rate version is prorated. |
The following are examples of the content of common Description on Bills along with how the line would look on the bill:
Description on Bill | How It Looks On A Bill |
Gas service %D | Gas service (prorated for 10 of 30 days) |
The
tree that follows contains a summary of the rate version's rate components. You can use this tree to both view high-level information about these objects and to transfer to the respective page on which an object is maintained.
The duplicate action in the action button bar enables you to duplicate a rate version and its rate components. Refer to
Duplicate Button in the system wide standards document for more information.
Parent topic
