Step Boundaries Based On The Number Of Days Of Usage And The Region In Which The Customer Resides
The following table illustrates the rate components necessary to levy a simple rate that contains the following charges:
• Monthly service charge: $10.00.
• Charge $.0832 for the first "x" kWh. X is equal to the number of days in the billing period multiplied by a factor that varies depending on where the customer lives.
• Charge $.1112 for the remaining kWh.
• State Tax at the prevailing rate (this tax is a percentage of a dollar value).
• County Use Tax at the prevailing rate (this tax is an amount per kilowatt-hour).
Seq # | RC Type | Value Type | Value | Bill Factor | Item Type | UOM/TOU/SQI | Step Range | Cross Reference | Calc Only | Result Type |
10 | Flat Charge | Charge | 10.00 | | | | | | N | |
20 | Service Quantity | Unit Rate | | BASEQTY | | DAYS | | | Y | Unit Rate |
30 | Service Quantity | Unit Rate | 0.0832 | | | KWH | 0 to 1 Multiply by RC: 20 | | N | |
40 | Service Quantity | Unit Rate | 0.1112 | | | KWH | 1 to 99999999 Multiply by RC: 20 | | N | |
50 | Summary | | | | | | | 30, 40 | N | |
60 | Apply To | Percent | | STTAX | | | | 10, 30, 40 | N | |
70 | Apply To | Unit Rate | | COUNTYTAX | | | | 30, 40 | N | |
Parent topic
