Proposal SAs Contain Billing Scenarios And Template Consumption
In addition to the pricing terms and the legal terms and conditions, a proposal SA also contains
billing scenarios. A billing scenario defines:
• The number of simulated bill segments that will be generated when a quote detail is produced for the proposal SA.
• The bill period of each simulated bill segment.
• The amount of consumption to be priced under each simulated bill segment. Note this statement is only true for non-interval consumption. Refer to
Proposal SAs And Interval Consumption for a description of how interval consumption is defined on a proposal SA.
A proposal SA's billing scenarios can be created as follows:
• You could design a workflow process to initiate a request to the customer to send their template consumption to you. When the customer sends this information to you (via a notification), the proposal SA's billing scenarios can be setup. Refer to
Workflow and Notifications for more information.
Parent topic
