Event Amounts May Contribute to a Balance
The event amount may be positive or negative, based on whether the event is accumulating points earned for the membership or redeeming points for the membership. For some types of memberships, these credit and debit amounts should be added together to produce the overall balance for the membership.
For some types of memberships, a balance is not applicable. This is true for memberships where the redemption of the points does not occur within the system. For example, if the membership accumulates frequent flier miles on behalf of an airline, the customer redeems the earned miles with the airline, not with your company. As a result, there is no need to calculate a balance for the membership.
If you want the system to calculate a balance, you must set a switch on the
membership type page. For memberships that calculate a balance, the balance may be viewed on the membership page.
Parent topic
