Service Credit Membership - Characteristics
The characteristics page contains information that describes miscellaneous information about the service credit membership. Open this page using > > > and navigate to the Characteristics page.
Description of Page
Characteristic Types. You can only choose characteristic types defined as permissible on the service credit membership record. Refer to
Setting Up Characteristic Types & Their Values for more information.
To modify a characteristic, simply move to a field and change its value. To add a new characteristic, click + to insert a row then fill in the information for each field. The following fields display:
Effective Date Define the date on which the characteristic becomes effective. The effective date defaults from the
Installation Record.
Characteristic Type Indicate the type of characteristic.
Characteristic Value Indicate the value of the characteristic.
Default Note. A service credit membership's characteristics default from the
service credit membership type.
Parent topic
