Recommending Scheduled Payments
When creating a Non-Billed Budget, you must select a recommendation rule. The recommendation rule establishes the amount to be paid and the dates on which the payments are due. In other words, the recommendation rule creates a recommended payment schedule.
The recommendation rules that you can use are specific to your implementation. The recommendation rule that you select can have default values for its parameters. If your implementation allows, you can manually override one or more of these default values. For example, you may be able to specify the period covered by the Non-Billed Budget and the day of the month on which the payments are due.
If your implementation allows, you can manually modify the recommended payment schedule to suit the needs of a particular customer.
Fastpath:
Refer to Designing Recommendation Rules for more information.
