Stock Location Inventory - Meter Inventory
This page is used to display the individual meters of a given type that are stored at a stock location. Refer to
The Big Picture Of Asset Inventory for more information.
Open this page using > > and navigate to the Meter Inventory page.
Description of Page
This page displays the individual meters that are stored at a Stock Location as of a given Date/Time.
The easiest way to display inventory for a given
Meter Type at a
Stock Location is to navigate to the
Stock Location Inventory - Main tab and find the
Stock Location. Then, click on a
Meter Count line.
You can restrict the list using the following filter options:
• Use the Meter Type filter to restrict the meters to those of the given meter type.
• Use the Badge Number filter to restrict the list to meters that have a badge number beginning with or matching this value.
Don't forget to click the search button after changing the filters.
The Select All / Clear All buttons are used to select meters to be transferred to another stock location. These buttons are enabled if at least one meter is displayed in the grid.
The grid contains the meter inventory at the selected stock location on the given date/time that match your filter criteria. The following information is displayed in the grid:
• Select box. Use this checkbox to select meters that you want to transfer to another stock location. This checkbox is enabled if the meter is currently stored at this location and location is tracked for the meter's meter type. Refer to
How to Transfer Assets To Another Location for more information.
• The description of the meter's Meter Type.
• The meter's Badge Number.
• The meter's Serial Number.
• The Manufacturer/ Model of the meter.
• The Location Date/Time when the meter was added to this stock location.
• If the meter was subsequently removed from this stock location, the Subsequent Location column shows either the stock location it was transferred to or the service point it was installed at.
Pressing the
Transfer Location button enables you to transfer the selected meters to another stock location. This button is enabled if at least one meter in the grid is selected. Refer to
Parent topic
