Process NDSXTR - Interface Notification Download Records (out of the system)
This process reads all notification download staging records marked with a given batch control ID & run number and creates the flat file that's passed to the outgoing notification software. Every NDS record references the recipient service provider and a notification download type. This process uses the service provider's notification download profile to determine the format of records interfaced out of the system. Refer to
Designing Notification Downloads for more information.
This process is rerunnable. You can reproduce the flat file at any time. Simply request this job and specify the run number associated with the historic run.
If you require different routing methods, you will need to create additional versions of this program.
Parent topic
