Workflow Process - Char/Context
The Process Char/Context page lists the context collection and/or the characteristic collection associated with the workflow process. Open this page using > > > and navigate to the Process Char/Context page.
Fastpath:
Refer to
A Workflow Process Contains Relevant Data for more information about context and characteristics.
Description of Page
Use characteristics and/or context to capture data to be used by your workflow process' event algorithms. Refer to
A Workflow Process Contains Relevant Data for more information.
The Characteristics grid displays the Characteristic Type and Characteristic Value for each attribute that can be accessed by the workflow process' event algorithms.
The Context grid displays the Context Type and Context Value for each attribute that can be accessed by the workflow process's event algorithms.
The values for Context Type are customizable using the Lookup table. This field name is WF_PROC_CTXT_FLG.
Parent topic
