Base Package Calculation Rule Descriptions
This section provides detailed descriptions of each of the base package calculation rules provided with Oracle Utilities Customer Care and Billing. The descriptions of the calculation rules below contain the following information
• Rule Name: The name of the rule
• Base Package Calculation Rule Business Object: The base package business object used by the rule
• Apply Calculation Rule Algorithm Type / Algorithm: The base package algorithm type and algorithm specified in the "Apply Calc Rule" system event for the rule
• Rule Parameters: Parameters used to define the rule (if applicable). Does not include common parameters used by all rules (see Common Parameters).
• Example: One or more example configurations of the rule. Note that all examples use default values for all Apply Calculation Rule Algorithm Parameters.
Parent topic
