Defining Calculation Groups
Use this procedure to define calculation groups.
Select Menu > Rates > Calculation Group > Add.
Enter a Name for the calculation group.
Enter a short Description and Detailed Description for the group.
Click Save.
You can also add a calculation group directly from the Rate Schedule portal. The Add Calculation Group action on the Pre-Processing Calculation Groups, Rate Version Calculation Groups and Post-Processing Calculation Groups sections allows you to create the calculation group and link the new group to the Rate Schedule.
To add a calculation rule to the calculation group, click the Add Rule link in the Calculation Rules List zone title bar. See Defining Calculation Rules for more information about creating calculation rules.
You can now create calculation rules for this group.
See About Calculation Groups for more information about calculation groups.
