Defining Calculation Line Category Types
Use this procedure to define calculation line category types.
• Select > > >
• Enter a Category Type name for the category type.
• Enter a short Description and Detailed Description for the category type.
• Define the Category Value and Description for each value for the category type.
• Click Save.
You can now reference this category and its values as either the Member Category or Target Category on calculation rules.
See "Calculation Line Category Types" in
About Calculation Rules for more information about calculation line category types.
Parent topic
