Viewing the Results of a Rate Check
The outcome of the rate check process is displayed on the Results tab. This tab contains the following zones:
• Main: Displays results of the rate check, including:
◦ Rate Schedule: The rate schedule used in the rate check
◦ Revenue Class: The revenue class used for the rate check.
◦ Bill Period: The start and end dates for the bill period used by the rate check.
◦ Consumption Period: The start and dates for the consumption period used by the rate check.
◦ Accounting Date: The Accounting Date used by the rate check.
◦ Calculated Amount: The calculated total for the rate check
• Calculation Lines: Displays the bill calculation headers and lines for the rate schedule.
• Read Details: Displays meter read details for the consumption used in the rate calculation.
• SQ Details: Displays a list of service quantities used in the rate calculation.
• Characteristics: Displays characteristics referenced by the rate calculation (if applicable).
• Trace Log: Displays logs that outline the calculation groups and rules used by the rate schedule. This zone is populated only if using a calculation rule-based rate schedule, and if the Should Trace dropdown list is set to "No".
Parent topic
