Color Options
The color option entity is used to define a combination of colors to be used in user interface components. The system provides a standard set of color options used for contextual insights.
To view or maintain color options, open Admin > System > Color Option.
This is a standard All-in-One portal.
The information captured on the color option depends on the record's business object. Refer to the embedded help text for more information.
