Linking to External Locations
If you want to include links to external systems or locations from within the system, you need to:
Define a navigation key that specifies the URL of the location. For example, define an external navigation key that as a URL of http://www.oracle.com/.
Define a navigation option that specifies from where in the system a user can go to your external location. For example, define a navigation option with a usage of Favorites or with a usage of Menu. Your navigation option points to the navigation key you defined above.
Add your navigation option to the appropriate location within the system. For example, have users add the navigation option to their Favorite Links or add the navigation option as an item on a menu.
