Sequencing of Objects in a Bundle
Bundle entities are added or updated to the target environment in the sequence defined in the bundle
Typically, the sequence of entities does not matter. However, sequence is important in the following situations:
• Entities that are referenced as foreign keys should be at the top of the sequence, before the entities that reference them. Specify zones last, as they typically contain numerous foreign key references.
• When importing a business object, specify the business object first, then its plug-in scripts, then the algorithms that reference the scripts, and then the algorithm types that reference the algorithms.
• When importing a portal and its zones, specify the portal first and then its zones.
• When importing a multi-query zone, specify the referenced zones first and then the multi-query zone.
• Always specify algorithms types before algorithms.
You can specify the sequence when you define the export bundle or when you import the bundle to the target environment.
Parent topic
