Invoke Function Steps
Functions were implemented prior to the introduction of business services (BS), service scripts (SS) and business objects (BO). The functionality is still supported, but the recommendation for implementations going forward is to use a step that invokes one of the above configuration tool objects in a script rather than defining a function.
Note:BPA scripts only. This step type is only applicable to BPA scripts.
Invoke function steps may be used to retrieve or update data independent of the page currently being displayed. For example, if you design a script that takes different paths based on the customer's customer class, you could invoke a function to retrieve the customer's customer class.
Fastpath:
You must set up a function before it can be referenced in a script. Refer to
Maintaining Functions for the details.
The following additional fields are required for Invoke Function steps:
Function defines the name of the function. The function's Long Description is displayed below.
When a function is invoked, it will either be successful or return an error. The next two fields control the step to which control is passed given the outcome of the function call:
• If Success, Go to defines the step that is executed if the function is successful.
• If Error, Go to defines the step that is executed if the function returns on error. Refer to
How To Use Constants In Scripts for a list of the global variables that are populated when a function returns an error.
Note:Error technique. If a function returns an error, we recommend that you invoke a step that transfers control to a script that displays the error message information and stops (note, the error information is held in
global variables). You would invoke this script via a
Transfer Control.
The Send Fields grid defines the fields whose values are sent to the function and whose field value source is not Defined On The Function. For example, if the function receives an account ID, you must define the name of the field in the script that holds the account ID.
• Field contains a brief description of the field sent to the function.
• Source Field Type and
Mapped Field / Value define the field sent to the function. Refer to the description of Source Field under
How To Set Up Move Data Steps for a description of each field type.
• Comments contain information about the field (this is defined on the function).
The Receive Fields grid defines the fields that hold the values returned from the function. For example, if the function returns an account's customer class and credit rating, you must set up two fields in this grid.
• Field contains a brief description of the field returned from the function.
• Destination Field Type and
Mapped Field define the field returned from the function. Refer to the description of Destination Field under
• Comments contain information about how the field (this is defined on the function).
Parent topic
