Script - Schema
Use this page to define the data elements passed to and from a service script. Open this page using > > and then navigate to the Schema tab.
Description of Page
The contents of this section describe the zones that are available on this portal.
The General Information zone displays the script name and description.
The
Schema Designer zone allows you to edit the service script's parameters schema. The purpose of the schema is to describe the input and output parameters used when invoking the script.
Refer to
Schema Nodes and Attributes for a complete list of the XML nodes and attributes available to you when you construct a schema.
The
Schema Usage Tree zone summarizes all cross-references to this schema. For each type of referencing entity, the
tree displays a summary node showing a total count of referencing items. The summary node appears if at least one referencing item exists. Expand the node to list the referencing items and use their description to navigate to their corresponding pages.
Parent topic
