Algorithm Viewer
The algorithm viewer is an interactive tool that allows you to view algorithm types (grouped by their plug-in spot) and their related algorithms.
To open the Algorithm Viewer, click the Algorithm button in the application viewer. The Algorithm viewer may also be opened from certain locations in the online help documentation.
Note:Data Is Generated. A background process generates algorithm information. Refer to Application Viewer Generation for further details.
